Hi, I bought a house a few weeks ago and the electrics are all from the 1950s. It has porcelain fuses and brown rubber wiring.
Now it has had a shower fitted recently before i bought it. Should the work not have come with a certificate?. Also should the wiring etc not have been inspected and tested prior to me buying as I hear it can default your home insurance?.
Anyways we decided to get a house rewiring and its coming in at over £2000 for a 2 bed end terraced 2 story.
I was wondering how much of the work I could do myself do save money?.
Basically it needs
consumer unit.
New lighting circuit to lights and switches up and down stair
Smoke alarms fitted
Exterior light front and rear
2 extra sockets in 1 bedroom
All single sockets converted to doubles
Humidistat fan fitted
Cooker hood fitted
Door bell wired
Cooker switch and connector relocated
New ring for kitchen to supply a washing machine and tumble dryer
3 new double sockets in kitchen
The upstairs sockets also supply 2 sockets in the kitchen 1 for a fridge and the other unused at the minute. There is also a single socket already.
Just wondering how much I can do of this myself?. From Scotland.
In my current house the bath fan and smoke alarms run off the lighting circuit using 6a mcbs. Also the kitchen is run off upstairs sockets ring.
In my new house wiring would be
40A for cooker
50A Shower
32A downstair sockets
32A upstair sockets
32A kitchen sockets
6A upstair lights + bath fan (1mm or 1.5MM?)
6A downstair lights + smoke alarms (1mm or 1.5mm)
6A External lights?(Could this be put on downstairs lights?)(1 or 1.5mm?)
6A or 10A combi boiler?. (This will be fitted by gas company)
I was wondering about loads in teh consumer unit though. In my current house its a split load so there are 2 80A 30mA Rcds and a 100A main switch. Now the circuits running on each are less than the 80A.
However in the new house the loads on each RCD will be higher. Could be around 108A on an 80A RCD?. Is this ok?. I have seen some wired like this. Or would it be better to have the load less than the RCD?. So maybe have 3 RCDs?. Like at the minute the shower has its own 63A 30mA RCD and is on a 50A MCB.
Also for the kitchen there was going to be a new ring mains. There is 3 sockets in the kitchen already running off the upstair ring. The new ring would supply washing machine and tumble dryer and probably 2 double sockets for microwave and food processor, blenders etc. The existing sockets will be used for kettle and fridge/freezer.
Any help advice would be great. I know there are a lot of things I cannot touch but I was wondering what I can do. I have an electrician say he would wire my unit for £300.
There is a lot of raggling to do in the kitchen as its a concrete floor so cables come from above. Is it possible to run cables behind skirting or under cabinets in conduits above the concrete flooring?.
The attic is covered in metal conduit containing all the brown rubber wiring. So these will all have to be cut and the wires ran through the joists under insulation so these will need new conduit to run through?.
Basically it needs
consumer unit.
Smoke alarms fitted
Cooker hood fitted
Door bell wired
40A for cooker
50A Shower
32A upstair sockets
32A kitchen sockets
