I got a builder in to knock through an internal wall and level up the resulting new room so that it could be tiled throughout the new room is approx 30 sq meters. The existing floor had a step down so it had to be levelled up. The lower level was cement and the higher level was floorboards. Cement was poured onto polysterene to bring it 12mm higher than the floorboards then 12mm marine ply was screwed to the floorboards. The problem is the floor is not level. The builder says its not level due to the floorboards not being level. The hearth where the chimney breast used to sit is also causing it not to be level. The builder now says I should get some leveling compound to level it up. I have also noticed that the floor seems to move up and down when I step on it especially where the plywood meets the cement.
Does anyone have any suggestions as to how I can go about fixing these problems, the unlevel floor and the bouncing floor? Will a tiler be able to level it out when he is tiling and is there anthing else that can be done to fix the plywood from moving, Can anyone also tell me if the buildder has done the job correctly or are the problems ocuring because he hasn't done things correctly thanks
i have reposted this question as think that i didnt give enough info when i posted it earlier this week hope it makes more sense and someone is able to advise thanks for any advise anyone is able to offer
