Doing my conservatory at the moment and want to check the electrics is ok or is there a better way to do this.
At present I have a 16 amp radial circuit supplying 5 sockets in the conservatory. from the last socket a 2.5 cable goes into the garage to a consumer unit which then supplys 2 garage sockets, and 5 in the shed as well as lighting on a 5 amp fuse.
There is not likely to be any more that 2 sockets being used at any one time so the draw on power will be negligible.
A friend has suggested turning this into a ring main by linking the lot and then putting a 32 amp breaker on.
What are your thoughts please.
