So I am trying to tile around my kitchen window. After my first attempt using a Mapi Tile & Grout product, I have decided to start again as half the tiles still completely loose overnight.
I suspect maybe I did not use enough adhesive (or this stuff is rubbish like the guy in the sticky says)? also, the walls are not completely flat.
As you can see in the photos now the bare plaster is showing do I need to use PVA?
I have a pot of Ever Build 701 tile adhesive this says to use PVA. ( I have also read reviews that this adhesive can have lumps in it).
Basically I don't want to waste any more money if this adhesive turns out to be rubbish I will have wasted money on it and the PVA.
The only alternative I can see is to buy some powdered adhesive (but even these seem to be without issue people say they set to fast).
So for now if I go ahead and use the Ever Build Adhesive do I really need PVA?
Photos here: https://1drv.ms/u/s!AjIDsSnZk6RutxcZS6V8FVUKpHuo?e=9qE4MT
