Advice Required R.E. Electric & Gas Meters
  • Thread starter Thread starter Taiguin
  • Start date Start date
T
Taiguin
Hey,
I've just had a homebuyers done and in it they mention a requirement for the Electricity Meter & Gas Meter to be in seperate locations. At present they are in the same cupboard, albeit on seperate sides (approx 1m apart). I've been scouring through BS 7671 but can't find a definative answer as to whether this is a requirement or not.
Any advice would be greatly appreciated.
Thanks in advance...
I don't think so. All I can recall is that gas pipes and electricity cables must be separated by 50mm (I think) OR the cables run in trunking/conduit
SB
It was built in 1935.
As for the spacing...thats all i found too sparkybird. They say in the report that if they are in the same cupboard they need to be seperated by a fire resistant partition.... all sounds bolony to me but wanted some advice and something to hang my hat on!
Ask them to supply details of the regulation which requires this.
If they can't, demand your fee back coz they're obviously just making it up as they go along.
don't think they will be able to back this up with BS7671.
There are so many properties around like this. Including mine.
you're making a huge assumption there..
it may be a requirement of the gas regulations, not the electrical regulations.. like if the gas pipe is in a duct, the duct must be ventilated, and pipe through a wall should be sleeved etc..
1. Gas pipes and cables at least 50mm apart
2. Gas meter and consumer unit at least 150mm apart
Unless some non combustible partition between them.
Nothing to prevent them being in the same place. Loads of houses have them next to each other.
Coljack that's the question I was answering and I feel comfortable with my response.
sorry, my response wasn't aimed at yours.. it was aimed at the OP trying to find the reg in the BS7671 electrical regs..
if you're a gas man, can I have a gsa pipe run in a partition wall or do i need a vent in it to let any escaped gas to, well, escape the void?
