Hoover AE230 (Quattro 1300) - _very_ strange fault!
It's almost as if it has a centrifugal clutch or something.
The drum is very hard to turn from stopped - until you get up to a certain speed (not very fast - I can achieve it by hand; well below a turn a second): then it turns easily! Until it slows below a certain speed - then it's as if a brake is applied.
This applies whether it is being turned by me, or the motor. The motor seems to have plenty of power, but it really strains during the start-stop phases of the cycle - the room lights flicker! It's fine on the medium speed or spin parts of the cycle.
This evening it was _very_ stiff to turn by hand (I've been in the habit of making sure it will turn at all before setting it going), and the motor is not turning it. Loud hum, and occasional squeaks as if a belt is slipping.
Is this a common fault, and if so what (if any!) is the cure?
