You can put pictures into your post by "copy and paste" or "drag and drop" or "attach a file"
Hey, I’m looking for some help trying to understand the problem with my dishwasher.
I have an AEG Proclean dishwasher and last night it stopped working with error i50.I’ve looked online and found that the problem might be with the pump, that there might be something in it. So today I today I took the pump off and to my happiness and surprise I did find something in it, it was a piece of glass.Once I took it away and started the machine, eveything started to work just fine, I was really proud of myself.
However, after 15 minutes or so, it started to leak on one side, around a piece of white plastic.This is how it looked before I started doing anything.
And these are the white hinges that I say it leaked through, the one on the left side
After this happened I also found some water on the floorboatd, and following the lead I believe it came from those two grey tubes that are connected to the white hinges and now I have no idea where they should be connected.. I’m referring to these two
Based on the photos I took before I started, I can’t see where they were.. i don’t know if they were actually connected to each other and now they split or where they're supposed to go..I’m looking for any help regarding these two tubes and possible reasons there would be leaking around those hinges.
