- Joined
- 7 Dec 2020
- Messages
- 6
- Reaction score
- 0
- Country
its descibed as 1200mmw not 2x600mm suggesting to me its a combined units probably has no side panels inbetween but who knows ?What about wiring, pipework, internal controls etc, that stuff must transition between each side in various places so its unlikely they can seperate once built up. Or does each half have its own mains lead and is effectively self contained?
Any ideas how we can separate our Fridge from Freezer?![]()
The model is an AEG 75578 and we cannot see how to remove the top front AEG cover which may conceal the top front fixing / joining bracket
There is clear daylight in the 5mm gap between the 2 units (except for the top front under the AEG hump cover which i cannot see) and each side has a separate plug so and with 3 other joining brackets that just leaves the one that may be under the hump/cover which i have pushed pulled hit with a mallet squeezed etc etc and although it does flex (made from soft cast metal) it won't 'unclip'. If i only knew this was the solution (a bracket under the cover) and which direction to apply force.... Thank you to everyone with their suggestions. We need to move it out of the kitchen when we change house.
