air admittance valve
4 Dec 2010
Somerset
am having trouble with the valve, the toilet when flushed with the valve fitted fills the toilet upto the top, I replaced it with a new one butI am having the same problem. I removed the valve and it flushes ok. CAN ANYONE HELP
Mick
fills the pan to the top - you have a partial blockage in the soil system
fills the cistern to the top then it just needs adjusting
i'm not sure quite what you were trying to get across to be honest ;)
by valve, you mean the part that lets the water into the system right?
the ball float or arm can be adjusted (or bent) to close the valve at whatever level you like.
Hi again
the valve I am talking about is the AAV at the top of the soil stack
sorry for any miss understandings
Mick
Hi
if there is a blockage why does the water flush away ok if I remove the AAV from the soil stack, this is what I dont understand
Mick
Ahh sorry, didn't read your post properly.
Puzzler, I don't even have anything in mind you can try, hopefully an experienced member will come along with some advice!
