what about the height of up F and E tank, the height shud be in relation to pump power
The height is around 2 -3 metres, the air vent slopes up an over and bends in the f/e tank.
maybe replacing the air sep for nwer one, of using the H wud work. i usually take the one u have out
The pump head has nothing to do with the height between FE tank and pump.You have replaced the previous pump with a higher head pump so at speed 2 the pump head is greater than the height between the pump and the FE tank which causes the air to be drawn in.
IF it was lying horizontal with the branches upwards - It looks like it would form the correct way to position vent/cold feedmaybe replacing the air sep for nwer one, of using the H wud work. i usually take the one u have out
is the air seperator I have, not very good?
Radiators which are cold at the bottom normally means the rads have sludge in them.The reason why I added the bigger pump was that I have two rooms that have quite large double skinned rads and they only warm up half way the bottoms are cold
My thought also. We also have the fact that the pump is pumping down, which can cause problems. Grundfos say:Nige F said:IF it was lying horizontal with the branches upwards - It looks like it would form the correct way to position vent/cold feed
That's goodI checked the air vent with the water cup method and it appears no air is being sucked in.
Thought that might be the caseThe rads that only heat half way are the furthest away from the pump and the largest
I didn't know that X400 was used to balance a system; I always thought it was a system cleaner. You learn something new every day on this forum.I have flushed the system and tried to balance the system with x400 however this did not resolve the issue.
Do you have a wall thermostat in the hall or living room? If you do, set the boiler thermostat to max setting. The wall thermostat will control when it goes on and off.I have noticed that the boiler thermostat ) potterton profile 80e gas is set to 3 should I increase the boiler thermostat so water is heated to higher temp at the moment the rads get hot but not really hot.
Very likely.I'm think maybe the water is getting colder on the last leg on the flow. I'm worried about increasing the boiler thermostat just in case I whack it up to maximum output, what are the pros and cons of this i.e increasing the thermostat may this bei the reason I'm not getting output on last two rads?
