I have a Myson oil boiler supplying 8 rads but am getting continually air in the system. A couple of plumbers have checked out the pipework, fittings and design (all OK) and I have also had a new thermostat fitted on the boiler but I still have the problem.
Only clue is that air does not seem to be drawn in/produced when boiler is on a lower setting (4 or below) but does on anything higher. I do have most of the TRVs turned down low but presumably the lower call for heat should be acnowledged by the thermostat.
Only other thing I can think of is a scaled up boiler producing hotspots and boiling up water above certain thermo settings.
Any ideas would be appreciated.
Tom
Tom
