- Joined
- 28 Jul 2014
- Messages
- 1,969
- Reaction score
- 566
- Country
The cold comes out the letterbox flap on the side, right? What are the dimensions?
A duct adapter with a flange maybe could fit over it...
You would need to take the side cover off the unit first to check if it is safe to put screws through the case. In fact, you could do the joining while the cover is off. Silicon or epoxy glue all round to get a good seal, then either screw it on or use nyloc nuts and bolts and leave it to set before you re-attach it.
