- Joined
- 22 Sep 2004
- Messages
- 28
- Reaction score
- 0
- Country
Hi all,
Apologies if this is in the wrong section.
I’m not sure if anyone has any insight but any advice would be much appreciated.
I’m looking to have a 5KW aircon unit installed in my living room.
I’m torn between 2 units which are simililarly priced supply and fit at around £2500. Daikin slghtly more around £150 give or take:
Daikin - FTXJ50MW / (outdoor unit - RXJ50M)
Mitsubishi MSZ-LN50VG2-W / (outdoor unit - MUZ-LN50VG2)
From what I’ve read up, Daikin seems to be the market leader. I like both units. I like the fact the Mitsubishi unit has a thermal sensor which detects body detects body heat and adjusts the temperature accordingly to your needs and has the feature to distribute are away from people. Whereas the Daikin unit only has infrared sensor which detects if people are in the room but not body temperature but allow redirects the flow of air.
The install for the unit would be above our in heads of where our sofa is lined up so having a unit which redirects the flow of air is a must.
Does anyone have any of these installed in their homes at all and which one would you recommend?
Any F-Gas registered engineers amongst us?
