    Dismiss Notice
Alarm control panel in garage
Discussion in 'Alarms, CCTV & Telephones' started by Sonic007, 4 Feb 2020.
  1. Sonic007
    Sonic007
    19 Dec 2019
    7
    Thanks Received:
    Country:
    Can I place an alarm control panel in a garage?
    It can get very cold in there and wondered if the battery would be ok in there too?
    Many thanks.
  2. Sponsored Links
  3. stem
    stem
    20 Jul 2005
    5,966
    Thanks Received:
    1,284
    Nottinghamshire
    Country:
    If you look at the specification for a control panel battery you will find it probably has an operating temperature in the range of something like -15 to +50 degrees C. In addition the power supply and components inside the panel will generate some heat, so the panel will be a few degrees warmer than the ambient temperature.
    Assuming that you have a control panel in mind, the specification should give you its operating temperature range. I've seen many installed in unheated warehouses so I can't imagine you would have a problem.
    • Like Like x 1
  4. The Pars
    The Pars
    17 Feb 2017
    93
    Thanks Received:
    17
    Country:
    You will have no problems installing the alarm panel in your garage. I have fitted loads in garages and never had any problems at all.
    • Like Like x 1
  5. Sonic007
    Sonic007
    19 Dec 2019
    7
    Thanks Received:
    Country:
    Many thanks. Much appreciated.
  6. secureiam
    secureiam
    20 Jun 2014
    3,897
    Thanks Received:
    461
    Lancashire
    Country:
    The garage just needs to be a dry place.
    • Like Like x 1
  7. SandyLyon
    SandyLyon
    21 Oct 2012
    615
    Thanks Received:
    137
    Lancashire
    Country:
    Most garages will be fine, damp and rodents are your main worries.
    If garage is joined to your house then the adjoining wall would be preferable to an outside one.
    • Like Like x 1
  8. Sponsored Links
Loading...
Share This Page
