OK so a few weeks back we had a power cut. Power came back on some time later so went to alarm control panel as the alarm was sounding, entered code and nothing happened, tried several times and could not get alarm to switch off / reset so turned power supply off at the mains fuse box and left it. Taken another look today after getting some note from here in other posts. I turned mains fuse back on, alarm sounding.....entered default code 1234 and alarm turned off...great!! I then turned mains off again, opened up the front of the control panel to check fuses, there are 3 off them, all next to each other, one was blown so replaced it. Closed cover, turned mains back on, entered code to stop alarm and then entered again to reset. Thought I would now try and set the alarm so entered code 1234 again, he panel started beeping slowly and I left the roon/garage! and closed the garage door. Within 10 secs or so the alarm just sunds again and all the zones on the panel are lit red? There are only 2 zones, downstaits garage and upstairs above the garage/office. Any suggestiions please?
As far as I am aware the battery will be around 3-4 years old
