Alarm recomendations
18 Oct 2006
Norwich
I'm thnking of replacing my wireless with a wired system..or at least run the wires in for it as I'm having some building work done
Any recomendations on :
ADE
Texecom
Pyronix
I want nothing too flash but certainly remote keypads, min 4 zones, part set...
Also previously I've had a system that didn't need a code to arm it....which is great if we get a cleaner again..as she doesn't need to have the code. - do these ones still exist?
<<Edit just spotted I have a brand new Pyronix Paragon RKPII keypad which I suspect I bought to add to the system I was mentioning above...can you still use these?>>>>
Thanks in advance
Personally I like texecom, and their systems can be configured for single button setting. They are also supplied with very clear instructions to help a novice installer.
I have very little experiance of pyronix, so can't advise about your keypad, but I'm sure one of the other guys on here will be able to help.
yea texecom :D
R8+
ive been looking after over 2000 of them for the past 3-4 years now, top class performance.
ADE: usually cheap crap.
Texecom: depends which panel. The Premiers are actually pretty good. The Veritas is reasonable if looked after but you can get a much better system for not much more money.
Pyronix: panels are terrible.
Id agree that the old ADE stuff wasnt great but far from the worst. But since honeywell has owned them we get less Accenta's/Optimas back than veritas's.
Does that include the R8 non plus model?
Yep :)
From the Veritas R8 (NOT R8+) installation manual
Option 3
Just to add...
I would recommend the R8+ over the R8 , as for the extra few quid you get 8 user codes , 250 event memory , you can add an LCD display later if required , comms interface if required ,plus all the features of the veritas R8.
