After removing a stud wall, I was left with a 10cm gap in the plaster on the adjoining external wall. I applied a thistle undercoat and then a layer of easifill on top. I’ve now allowed it to fully dry (over 24h) but I need to add in a second layer of easifill to make it flush and level with the surrounding walls. I sanded it in between as I realised the wall either side had a slight ridge. Where I did a similar thing over a piece of plasterboard I fitted in the ceiling, the second layer of easifill was a bit flakey and doesn’t seem to have adhered properly.
Should I have applied the second layer of easifill sooner and not sanded in between? How can I stop this happening a second time with the wall now that it’s fully dry? Do I spray the wall with water or a water/PVA solution?
