I wonder if anyone can give me some advice.
I am having problems with an Alpha 240/280E boiler. I am desperate to conserve the boiler for 6 months as I am about to refurbish and relocate my kitchen and fitting one just now would cause havoc and high costs.
I have read the existing postings about the diverter valve and the problem may this part (it takes time and luck to get warm water and the rads heat up when hot water is selected unless I turn each radiator off) however I beleive I must have another problem as although the diverter switch appears to come out fully a few seconds after the boiler has fired up it turns off for an equal or longer time. I have also noticed the pressure is continually above the green limit but however much I bleed radiators it just returns back again.
I would be grateful for any ideas as I don't want to buy a new diverter valve (£205+) if I will then need part after part.
Thanks a lot to anyone who can Wendi
