Paul Barker said:You can do this job without removing gas valve
didnt think you had to cheers paul
wendiff said:Hi everyone, I'm back
Just fitted everything to plan EXCEPT for the following probs, so anyone still got any ideas for me!:
1. The boiler fires up beutifully, hot water comes out galore but minutes later there is a very loud whooshing, croaking, or clanking sound (not sure how to describe but is is as if pressure is building up or air or something) and the pilot goes out. Start again and the same again, now 3 times. Something obviously not right.
2. Tiny bit of a leak (seems to be reducing on its own which may be normal) from both push-fit connections connecting diverter valve to the heat exchanger.
I'm learning!
regards Wendi
