Hi folks,
Good news is I hadn't filled the system properly and misunderstood the noises so pump is fortunately not EX and now fully functioning with no noises... and the pilot stays on.
From here this posting needed extensive changes from this morning as it was all rubbish thanks to my just receiving the manual from Paul. Thanks Paul. Now it is most definately HIP HIP HURRAH.
CH working - the timer must have got turned on during the work and as I never use it it never occurred to me. The manual was a dream, found prob in seconds and voila HW came on.
1) Only thing is that as prior to diverter change, when DHW turned on boiler fires up... few minutes lovely hot water (much hotter than before I must say)... then flame reduces a couple of minutes... then flame rises again... and ect. etc. until several cycles later boiler fires down a couple of minutes with no flame... then fires up again, and etc. etc. etc. Water temp variation only realy noticeable in bathroom where pressure is much lower. Is this normal?
3) Pressure appears staying on green now although there is an occasional lighe whistling sound down under when everythings off and an occasional moan if I up the mains pressure - will observe but doesn't appear serious and also probably normal?.
I reckon its fixed and should last a few months thanks to all of you, BUT, and there had to be one, next job, I have is finding the tiniest (got little space and it only needs to run 4 rads), simplest, quitest, ecologicalist (!?), combi for when I redo the place. Any ideas?
Thank you all everso everso much everyone, anything I can help any one with just ask... not plumbing please!
Wendi
