Simple there are a lot of components on that board once the relay is broken of it is easy to identify the pins of the relay. simply turn the board over heat up the pins on the back of the board and they will fall out under gravity much neater job simple without having to tug on the relay as you are trying to desolder 4 pins using I presume a de- solder pump or braid.
