Boiler: Alpha CB28
Age: 4 years
(I think) there is a seal on the Alpha CB28 just below the DHW flow valve assembly. (In my servicing instructions it is Fig. 23 nadd 27.) This seal appears to be passing water so I am contemplating removing the flow valve assembly and replacing the seal. The leak is intermittent.
My main concerns about attempting to replace the seal are making sure that I have all the relevant seals and spares to hand:
To remove the DHW flow valve assembly, I need to remove the DHW heat exchanger. Will I need to replace the seals and if so what is the relevant seal kit?
I also will have to remove the diverter valve assembly, which the DHW flow valve is part of. Will I need to replace the seals and what is the relevant seal kit?
The two fixing screws that hold the DHW flow valve in place on the seasonality valve appear corroded and I am fearful that in trying to remove them I will shear the heads - any tips and advice on the best way to approach the removal of these screws? What is the purpose of the two fixing screws below the flow valve assembly, and can I get replacement screws and seals (as I think it is seal that is passing)?
Any other advice most welcome - it has been a while since I have done any plumbing work.
Age: 4 years
