alternative power
any ideas as to what geni (continuous) output will be required?
If it's just for the boiler/pump, then pretty much the smallest available - a few hundred watts will be plenty.
However generator also means petrol - and storing petrol for any length of time is usually a fail as it degrades and becomes useless fairly quickly.
I've always heard that but never found it to be true - I have petrol that is years old and still works fine in my genny. I've even used it in the car by using it to top up a 1/2 full tank, so that it is only a fairly small proportion.
Buy a petrol mower, then you'll have to have stored petrol, and it will be continually replenished with fresh.
My boiler's electrics (presumably the pump) is rated at 42watts at full load, but then doesn't an electric motor draw a lot more at start-up, so any idea as to what geni output would be adequate?
As for fuel degradation, my old V8 will take care of any that needs replenishing :rolleyes:
As I think has been said before, I think you would find it impossible to buy a genny which was 'too small' to supply the start-up current of a motor which represented a running load of 42W. In the very worst case, the start-up current of a small motor will only be 'a few times' it's running current.
Kind Regards, John
