I have 6 radiators in a small 2 bed flat and a potterton suprima boiler and open tank system (I think...). It's an old system.
Since the winter my central heating has been playing up. It's been making gurgling sounds generally when the boiler is on, especially when the pump pushes hot water round, you can hear a trickling sound from one radiator, and a couple of times I've heard banging. A month ago one of my radiators started leaking (from a hole in the radiator) in my bedroom, which I got replaced.
Since then all the radiators won't heat up as fast as normal. There are two radiators specifically that are causing problems. A tall 'designer' radiator near the boiler, which needs constant bleeding and I can hear this trickling sound when the heating is on. Although I did manage to get it to bleed to the top when I shut off all the other radiators. When I did manage to do this, the water was not clear, it was very pale brown. But when the whole system is open, it needs constant bleeding and I can take the bleed valve off and nothing happens - sometimes a bit of air but then it stops, no water. It only gets hot in the very bottom (about a sixth of the radiator's length), not the top. The other radiator near this tall one in the spare bedroom also needs a lot of bleeding, but not as much, water comes out almost immediately and it stays hot all over. Again the water is a very pale brown. All of the water from every other radiator is clear.
I have tried bleeding all the radiators continuously to no avail. I have also tried shutting off all the other radiators apart from the ones I am having problems with one at a time to try and force the problem out as I thought it might have been air. I have also bled the pump. I tried balancing the system too.
I had a plumber round yesterday and they said that (amongst many things) that my gate valve needs replacing (it's 15mm rather than 22mm) and that the system needs a power flush as there's sludge/sediments. Does this sound right? He's quoted £350. I can't really afford that right now though but I'm thinking that if another radiator might leak because of this then I should do it. I also want to upgrade the system over the next couple of years or move, so I'm not sure whether it's worth it. But then I don't want to end up having to replace the system sooner just because I didn't get a power flush.
Advice would be appreciated on whether there is anything else I can do to solve the problems I'm having, if I need a power flush or there's something else a heating engineer/plumber can do, and if there isn't whether this is a good price for a power flush.
Many thanks.
Many thanks.
