was the system cleansed
Perhaps, but even if the primary Hex is SS, you still don't want softened water in the system because of it's corrosive effects on the system generally (so I'm told by DIA). On the other hand you want softened water feeding the DHW side. So the normal location of the filling loop isn't appropriate.corgiman said:aluminium heat exchangers (central heating side) will corrode very quicky with treated water but stainless steel Primary heat exchangers will not.
doitall said:corgiman said:fitz1 said:what was total cost.cxi is stainless coil hx
thanks for that just check on glowworm website, so treated water to it aint a problem, in fact its adivisable to inhibit scale build up
nice looking boiler
You shouldn't put softened water into steel radiators.
corgiman said:what else on the system could suffer from treated water??
fitz1 said:has inhibitor been added
festive said:fitz1 said:has inhibitor been added
No inhibitor in sight...ill take one more pic of all pipes.. one sec <gets out of bed>
corgiman said:just asking why not steel rads but yes to steel heat exchangers??
