I'm converting a old industrial building in to a couple of flats.
The 1st floor flat will have a large jacuzzi bath in the bedroom
I'm also having a wetroom. The waste pipes are 40mm
So far so good ...
I was going to have a straight 7 metre run of 40mm pipe which I was planning on connecting the wetroom, jax, and kitchen/laundry waste in to.
Am I setting myself up for problems? The reason for the single run of pipe is only one core hole thru the solid wall. It will also look a lot neater outside.
The concern is ... as the jax/washing machine is discharging a problem in the waste causes it to back up and flood the wetroom
See sketch
So far so good ...
See sketch
