Yes, although I don't recall ever having seen quite that, it occurred to me that a 'metal equivalent to the plastic wall plug' should be very possible. One imagines that a 'tube' of a soft metal would do much the same job. As well as being expensive (and toxic) lead (which would probably otherwise be the ideal) would probably melt too easily, but thin aluminium would probably work OK.I suddenly remembered that I've seen (and possibly used ?) in the past a metal equivalent to the plastic wall plug. And on checking, I see that there are indeed such things still available. So in that respect, if the question is whether the plastic plug in the wall is a weak spot in a fire, then metal ones are available and therefore don't need any changes in working practices to use.
Kind Regards, John
