I'd be grateful for some advice
After the installation of a new fusebox replacing a melt-wire type, I find that my American Fridge is immediately tripping the MCB on its circuit, apparently with a grounding problem. I have been advised to buy a new fridge (by my local fridge seller), as such problems are too hard to diagnose.
The fridge amp rating says "3.50 r1234A 0.14Kg" and the MCB is rated at 32A, part of a Square D board RCCB 80A - 30 milliamp.
Discussions I have seen elsewhere have suggested that fridges have a tendency to ground and therefore are considered by some to be not suitable to be connected to e.g. GFCIs.
My questions are:
does the above entail that the fridge is defective, or is it possible that the MCB is too sensitive?
If so what MCB would be appropriate?
Otherwise, is there any maintenance or cleaning that could be done to reduce or eliminate the grounding?
Before I replace a fridge that appeared to work perfectly well when it was connected through the old fusebox I want to be sure that it is necessary.
My questions are:
