Evenin' all.
I'm in a samba regae drumming band, and when all costumed up, i look like this:
//media.diynot.com/178000_177042_39297_66025921_thumb.jpg
What i want help with is the best way to go about fixing a water bottle holder such as this:
//media.diynot.com/178000_177042_39296_31384975_thumb.jpg
To the vertical threaded rod i've labeled in the pic of the drum.
I'm got about 50 drums to do, so it needs to be cheap, it should be able to stay high up on the rod, so it'll need some nuts in there, but i'll need to be able to take the bottle holder off without dismantling the whole drum
Does anything like this exist?
//media.diynot.com/178000_177042_39298_81691963_thumb.jpg
If you can imagine the red bit is threaded so it's like a joint connector nut but with a thickish washer on the end. The drum rod passes through the white hole and held in place with two nuts.
I'd welcome any and all suggestions.
