Ancient Cannon 144 gas oven - How to light it
28 Jan 2012
Southampton
Hi, we have just moved into a house with an ancient gas Cannon gas oven. I cannot work out how to turn it on. The hobs work fine. It is clean and looks to be in good repair. Make is 144 with eye level grill and plate holder. Any suggestions welcome.
On some you have to set the clock before the oven will work.
Or maybe yours is too ancient to even have a clock?
Yes they had a manual & timer setting controlled by switches either side of the clock. Presumably yo have the oven pilot light lit. Not sure if you had to light that model manually or it had ignitors for hob & oven.
