The other day I happened to go into the loft, and noticed a small amount of condensation on the underside of the roofing felt. The space between the rafters is insulated, and judging by the dry moisture tracks on the underside of this insulation this is not a new problem. There's no sign of any rot in the timbers so presumably this problem only occurs in very cold weather.
I've read this forum's Wiki on this topic and a two part solution occurs to me. One, there's little air movement in the loft and the internal space at the roof edges is too limited to allow easy access to clear away any insulation or create new gaps, so I need to have roof vents fitted. Two, the bungalow has a concrete floor and all CH pipework enters the loft through the ceilings, so I need to make sure all those gaps are sealed, along with the loft hatch.
Is there anything else I should consider doing to help the situation? We have extractors in both bathroom and kitchen and the insulation on the loft floor, which is boarded over, is minimal, so I can't imagine that the loft is particularly cold.
Thanks.
Thanks.
