Hi guys, i am after some of your valuable knowledge please.
I am about to erect a summer house and wish to add power.
A few points that i think useful:
1. The summer house is approximately 5m from the garage, which has power. the power is fed in what i believe to be 6mm swa to the house.
2. The house is approximately 75m from the garage.
3. I want 5 double sockets. for minimal usage (phone chargers, small tv, small fridge freezer.
4. I want a 2kW wall heater (no decision as to type yet)
5. 4 lights internally, operated by two switches for two lights each.
6. A couple of outside lights - probably eco bulb type, not floodlights!
Now, i am not an electrician, but have plenty of experience in installation etc, but i want to save as much money as possible. I am more than happy to get it approved and tested professionally, but feel that i can do the bulk myself with a little guidance (your part?) please.
I would love some guidance on the best way to do this. I cannot bury the 5m of cable from the garage to the summerhouse, so it will be on a raised post and rail between the two, specifically for the cable.
the garage is feeding a socket and a light internally. Some outside lights in the garden which i believe to be 4mm swa are also fed from the garage.
I want this to be professionally signed off at the end of it, but the calcs etc for what i need to do for the new, and maybe upgrade to the old is the main issue for me.
Final q, is it nessary to be a ring main in a single room? can i run one way round the room from the main board and also then run the other? if that makes sense.
oh, i should say, that i want to run the power from the garage rather than a new feed back to the house
Thanks all for your time in advance.
Keith
Incoming supply
Incoming earth
Main board in house
Garage board
Keith
Incoming supply
Incoming earth
Main board in house
Garage board
