I'd appreciate any thoughts or advice on this. I'm inclined to remove it but it looks like part of the original build so I can't help feel it serves a purpose but it just looks like empty boxing-in to me.
This boxing spans 2.1m across the centre of the kitchen ceiling. It's about 25cm deep x 12cm wide. It doesn't contain any pipes or cables – totally empty as the photo shows (I removed the TG boards on the open side). It doesn't appear to be fixed to the wall at either end and only seems to be nailed to a couple of joists a third in from each end. The lathe and plaster ceiling butts up against the boxing with the header of the boxing fitted directly to the underside of the joists.
View media item 82372http://www.diynot.com/network/33frog/albums/21978/82372
By the way, it's on the ground floor of a 1930s maisonette.
Any ideas what it is and if it's safe to remove?
Thanks in advance.
Thanks in advance.
