Hi guys I wanted to add some fluted mdf wall panels to a wall that has a couple of flush wall lights. Has anyone done this and able to share any thoughts on how to get a nice finish? Thanks
With a multi tool, cut out a suitably sized section of the 3D panel, then fill the gap with a piece of standard 18mm MDF to provide a level surface for the fitting.
Caulk any remaining gaps.
