Hi, I've purchased some wall lights that I'm hoping to create two wooden bedside panels to fit them which I can plug into the wall. Which seems straightforward enough.
However I want to add lights switches on each panel, similar to what hotels do.
So a piece of MDF with batten to elevate from wall. the wall light fitted to it with hole drilled through to hide cables behind.
The light fixture have earth cable because they're metal, if I use a wall light switch what do I do with the earth wire? As these are normally attached to back plate of the socket.
Ideally I wanted to use a 16A rocker switch so I can place it on the side of the panel discreetly but not sure how I'd wire this.
Any ideas, suggestions welcome
