I'm looking to install two bedside wall lamps. One on each side of the bed.
On each side of the bed is a socket.
I have done some searching on here and google and was just wondering if you guys could confirm something for me.
The sockets are part of the ring main. Am I right in thinking that I can spur off each one to an FCU and then to the lamp? If that is the case what size should the fuse be as I had read that it should be a 3amp fuse.
Thanking you in advance.
