Quick question. I am installing two bedside lights which then have two 2 way switches each so they can both be switched from either side of the bed. I know I need to get the power from the ceiling light and chase down the wall to each light and one switch. The question is on the wire from each of the switches to the other switch. Could or should I chase a channel horizontally so it goes behind the bed or should it go back up the wall and down the other side?
What is the correct way to do it?
Thank you
Mark
Thank you
Mark
