Do you have any problems with doing so?
I'm a solid wood man (between the ears anyroad! . Limited experience with laminates and so on really. I thought negative rake blades were for chop type "overhead" saws more than anything. I'd assume then that you need to make sure everything is set up right (as it should be anyway) so the work is held down if it tries to lift? And / or power feed?negative rake i assume laminate
completely normal
Even though it's regarded as a relatively unsafe practice? The safest way to set-up a blade is to have the teeth projecting just above the surface rather than raised to the maximum. Your trechnoque may work initially but is much more prone to chipping out as the blade blunts as well.
Call me risk averse, but I'd have to refuse that request. I've seen enough stupid accidents with table saws in a forty plus year career to want to be the instigator of another one. IMHO table saws are not an ideal tool to fool around with.I have tried to "make it go wrong" but it won't. If you can suggest a situation where it will be dangerous, let me know and I'll try it out.
