Anyway to repair this Power washer cable? (photos)
Here is a photo of the power cable/Electrical cable that plugs into the wall.
Mmm, I really think that photo of the black thing with the missing chunks showing the white thing is the high pressure water hose. It bears the text “max 60*C” which is typical for a jet hose:
Anyhoos:
That there with the white showing is more likely to have been damaged by lying on an abrasive floor and being vibrated by the machine. You can see where it has a flat spot worn into it between the white parts.
You can repair this with tape or heat shrink, or rubber paint etc. The outer cover doesn’t contribute to the pressure carrying capacity; that is offered by the now exposed white braiding. If that wears through the soft inner hose will burst
If you have dropped a log on the power cable and flattened it, if the outer sheath is unbreached just monitor it each use, no treatment required. If the outer sheath is damaged but the coloured cores inside are not, you can effect a repair with insulation tape.
If the inner cores are damaged and showing copper, replace or repair the cable. A simple repair strategy could be to cut the cable at that point and use an IP68 waterproof male female connector pair. This would also in future let you buy another such connector pair and fashion an extension lead that can be fitted or not fitted as you choose. Ensure you get a connector with an amps rating appropriate (higher than) for the machine. If your machine is rated in watts (eg 1.6kw, or 1600watts), divide watts by 230 to convert to amps
Are you saying that you believe he/she was mistaken when writing:
I would have thought that most people could distinguish between an electrical plug and something connected to the end of a hose?
Most people
It is a very confusing picture. The damaged component is on a reel and does appear to be a hose while in the top RH corner of the picture is what looks more like a cable.
Yes, as robin has pointed out, it's actually clear that the stuff on the reel is the hose but, as I implied, I find it difficult to understand how the OP has seemingly managed to confuse electrical plugs with hose fittings :-)
Yes, you're clearly right - not just the "60C" but also what looks like "180 bar", which is the same as the 2610 psi marking on the hose you illustrate. I'm not sure hoe the OP has managed to confuse a hose and a cable!
For clarity the markings you show are also to the bottom left of the hose damage.
agreed that somewhere along the way OP has definitely got confused.
...You can repair this with tape or heat shrink, or rubber paint etc. The outer cover doesn’t contribute to the pressure carrying capacity; that is offered by the now exposed white braiding. If that wears through the soft inner hose will burst
The integrity of the hose is now compromised and personally I'd not attempt any sort or repair other than a cut out the damaged section and join with properly crimped highpressure fittings. Quite honestly the cost of the fitting plus the crimpers or getting it done probably outweighs the cost of a replacement hose.
It's only the outer sheath which appears to be damaged/protection against mechanical damage, the pressure is contained by the inner hose, and the stainless steel wire armouring. Electrical tape, or self amalgamating tape, or similar, while be a perfectly satisfactory repair.
