Apollo Fanfare 15/30 making banging noise.
27 May 2008
Northamptonshire
hi,
i have an apollo fanfare 15/30 which is making has been making aloud banging noise all through the day. last year in feb i had the gas valve, fan and thermocouple changed. I was told not much else could go wrong. any ideas please?
also I was looking to replace the boiler in the summer, when i could do without heat and hot water for a few days. can anyone recommend any good replacment boilers or installers in the northamptonshire area? i have a 2up, 2 down house with 5 radiators.
thanks
Is it a constant noise or just occasional throughout the day
If a fanfare is making noises its usually a choice of 3 things
1 boiler stat allowing system to get hotter than it should but this would normally make the overheat stat trip and drop the pilot out.
2. pump on too low a speed(or stopping) , boiler is low water content so pump should be on 3
3. there is a pump over run stat on an appollo that also controls the pump in normal operation these stick and can cause the pump not to start up till heat is sensed within the boiler casing which results in about 15 seconds of banging when C/H or H/W stats demand heat.
