- Joined
- 29 Feb 2004
- Messages
- 31
- Reaction score
- 0
- Country
I have encountered a fairly recent (approx. 3 years) gas shop Magiglo DFE gas fire installation. The brick flue has been lined with 5” S/S, but the MI states “16 Elite Thermobox pack incorporating Trim Switch control should not be installed on a 5 (125mm) flue system due to increased switch temperatures caused by reduced flue flow” and the minimum dimension is 55mm. BTW the 8mm copper gas supply pipe is wrapped but not sleeved through the external cavity wall into the fireplace opening.
The nominal maximum heat input is 6.9 kW (gross) so there is no permanent airvent.
Should this be classed as NCS even though it hasn’t been installed to comply with the Manufacturers Instructions or is it serious enough to be classed as AR?
I would be obliged if anyone can shed some light on this (for me) grey area.
