Are ball valves flow restrictors?
FLow regulators have active elements inside which increase the resistance as the flow increases, so it "flattens off", if you follow, at the desired flow figure regardless of pressure.
They aren't perfect and they deteriorate, but they aren't too bad.
The "active element" is usually just a little rubber O ring being pushed into a tightening space.
Full flow isolators have "no" resistance, and smaller bore ones make no effective difference at low flow rates.
Bigger problem with cheap and nasty little isolators is that they're crappy, and leak.
So basically using isolators won't effect the volume and pressure of the shower?
Depends on the shower, probably needs full bore ones.
