773 168 is the wago part number, suitable for solid core cables they are on amazon but a lot dearer, just ensure they state WAGO as theres many clones
Perhaps I may be mistaken about what can be achieved with the traditional connectors. As a teenager, I did some very dodgy things with such connectors in my experimental projects. I didn't kill anyone and I only blew a few fuses. As a grown up, I'm aiming for something that'd be safe in the future rather than quickly cobbling together a Heath-Robinson solution. I can assure you, even if my lack of confidence would be unfounded, I'd not feel confident about a traditional connector if I were to install it with more than 2 wires per screw.You are mistaken
Yes. You seem to have some strange ideas.Perhaps I may be mistaken about what can be achieved with the traditional connectors.
They do not blow fuses and are perfectly safe now and in the future.As a teenager, I did some very dodgy things with such connectors in my experimental projects. I didn't kill anyone and I only blew a few fuses. As a grown up, I'm aiming for something that'd be safe in the future rather than quickly cobbling together a Heath-Robinson solution. I can assure you, even if my lack of confidence would be unfounded, I'd not feel confident about a traditional connector if I were to install it with more than 2 wires per screw.
You haven't seen the technology projects I experimentally cobbled together from reclaimed scrap when I was a teenager. If you had, it is inconceivable that you could ever have considered my mains electricity devices 'perfectly safe'. I'm not saying that you can't use the traditional connector product safely - I'm only saying that I'd lack confidence in the quality of my work if using that product for my current objective.They do not blow fuses and are perfectly safe now and in the future.
Their use is not cobbling together a Heath-Robinson solution.
Many thanks for that. I'd found this kind of push-in terminal... though only after being pointed at Wago. It's really helpful to have the Wago part number confirmed. They do look pricey on Amazon... but, perhaps, that's because they're sold in packs of 50. Farnell has the same part priced at 33p each (ex VAT & Delivery) and sells them individually. I am really liking the look of the 'bulk pack' Wago 221 connectors for other DIY... 90 connectors for £12.50 is an average of ~14p each - which I consider very cheap. The only frustration is that I can't order a 'pick-n-mix' selection. If I had been aware of these Wago connectors a couple of years ago, when I wired in replacement sockets (on existing wiring) in my house... they'd definitely have made the job much quicker, easier and neater.773 168 is the wago part number, suitable for solid core cables they are on amazon but a lot dearer, just ensure they state WAGO as theres many clones
Awesome - Many thanks. A bargain too!you can get 8 way wagos
Wago 2273 8 Way Compact PushWire Connectors
Simple, reusable 8 way push wire connectors for solid conductors. Transparent housing to ensure the connection remains visible.• 8 way push-in solid core conductors• Easy to use• Compact, reusable design• Transparent housing• 1 x test port for easy testing• Can be used in maintenance free...www.toolstation.com
I am definitely inexperienced with respect to standard (modern) electrical installation techniques. I'm amateur not professional. I don't agree, however, that I have novel preconceptions about what is (and is not) safe. My amateur approach likely does result in me being overly cautious at times - I am completely happy for it to be that way. If I anticipate that wires may pull out of the connectors I've chosen... that is something I would consider an issue for me. It's probably not a safety issue in the way that omitting earth, or using inadequately rated cable, might be considered a safety issue... but it could be a safety issue in the sense that I want these lights to "just work" - indefinitely. I don't want to find myself in the dark, tripping over things, if my installation fails. I don't want to risk tripping the consumer unit if a wire might pop out.The OP is evidently inexperienced in standard electrical installation techniques and does indeed have some rather novel preconceptions about what is and isn't safe.
I use traditional choc-block connectors on a daily basis to join together multiple wires, often with far greater current draw than s/he is dealing with, and am certainly not leaving a trail of fiery destruction and shocked/electrocuted clients in my wake![]()
Good heavens no.Don't pay extra just for fashion then.
You shouldn't doubt your concerns. multiple wires in a terminal can be difficult to fit, depending on the location and space available, and it is a fairly common failure, especially when cabling is moved and the cores can be dislodged. EFL is sort of correct that that they are more secure in an ideal sized receptacle but it can be very difficult to source the ideal size for a particular wire but then making say 8 wires off into a round hole gets difficult, especially when the size of the insulation comes into the equation.I am definitely inexperienced with respect to standard (modern) electrical installation techniques. I'm amateur not professional. I don't agree, however, that I have novel preconceptions about what is (and is not) safe. My amateur approach likely does result in me being overly cautious at times - I am completely happy for it to be that way. If I anticipate that wires may pull out of the connectors I've chosen... that is something I would consider an issue for me. It's probably not a safety issue in the way that omitting earth, or using inadequately rated cable, might be considered a safety issue... but it could be a safety issue in the sense that I want these lights to "just work" - indefinitely. I don't want to find myself in the dark, tripping over things, if my installation fails. I don't want to risk tripping the consumer unit if a wire might pop out.
I have no concerns about 'chock-block' connectors and inline use of the traditional two-screw terminals where there are 1,2 or - perhaps - 3 wires clamped by each screw. Current draw is not a relevant concern in my context - but securely clamping the wires remains a priority for me. With more than 2-3 wires, there's a bigger risk that wires will pull out as the wiring is pushed into the box and the switches are secured on the front. I didn't want to take such risks with this project. I don't want to pass comment on how you meet your clients' requirements - I'm definitely not trying to criticise your use of any product you choose for any of your jobs... or saying there'll be any issue with your work. I'm only saying that I didn't feel that the traditional product, with which I was already familiar (which I have abused horribly in my distant past) was optimal - for me - for my current project.
so do I but I'm finding many now have some restriction in them, especially those with fingers to protect the wires.Must admit I favour the two screw approach where possible
