My Boiler was leaking a few weeks ago every time the heating or water was on it would leak.
Having called someone out to look at it there was a connection which was loose which they manged to tighten and stop the leaking. Since then the hot water doesnt seem to work and the heating needs to be on at the same time to get hot water.
Any reasons what the problem could be? If I loosen the bolt where the leak was and re tighten will that make any difference is it anything to do pressure, as I have no idea.
Was working prefectly fine before the leak was fixed.
