Ariston PowerMax Boiler - Hot Water problem
18 Apr 2011
Hertfordshire
My Boiler was leaking a few weeks ago every time the heating or water was on it would leak.
Having called someone out to look at it there was a connection which was loose which they manged to tighten and stop the leaking. Since then the hot water doesnt seem to work and the heating needs to be on at the same time to get hot water.
Any reasons what the problem could be? If I loosen the bolt where the leak was and re tighten will that make any difference is it anything to do pressure, as I have no idea.
Was working prefectly fine before the leak was fixed.
Quite clearly they have not fixed the leak properly so that the boiler continues to work.
I dont know what they touched from your description so cannot advise about that.
The obvious solution is to call them back to do the job properly.
I got them to come out and they said nothing is wrong with the boiler.
I have shown below on the image where the leak was any indications to what the problem could be?
Your boiler is a potterton powermax.
The leak was from your hot water flow switch.
It looks like your flow switch is upside down/twisted through 180 degrees.
The reason you get hot water only when the heating on, is that the DHW pump stirs the store water when there is a heat drop in the store.
Isolate the cold water supply to the boiler, loosen the black plastic 'nut' twist it 180 degress so that the grey wire is at the bottom and retighten. If it leaks after tightening and restoring the supply you will need a new one - they aren.'t expensive. :wink:
I seem to have the problem again I'm not getting hot water but if I turn on the heating I seem to be ok
What could be the cause?
Is it worth paying for boiler cover with a company?
Having done the following below (instructions given previously) seemed to have resolved the problem but the grey wire seems to be ok now.
The water flow switch is now leaking as the black grumit has cracked.
Can I buy this? Can anyone give me a quote to replace or fix?
