Ariston washing machine wont take in hot water.
2 Dec 2004
Ariston washing machine wont take in hot water. Have checked water flow to machine which is fine and changed water inlet valve to no effect. I don't think the cold water is being heated either. What's the problem? :cry:
was it a new valve you tried in the m/c?
have you looked yo see are there any bad connections
It is a new water inlet valve I have tried. Which connections do you suggest I check? the electrical wires appear connected and the water hoses are ok Thanks
does the valve click when it (apparently) opens try a screwdriver on the top you should feel the pull from the coil if its working :)
if you turn the water off you can here them hum (if they work)
I can hear them hum when the water is turned off.
