Hi
We will buy cheap washing machines, just had same problem with my A1635 and checked the obvious disregarding all thougths that it might be a level sensor or blocked pump filter or faulty temp switch or duff solenoid or printed circuit board and yes the motor brushes were worn.
Replaced brushes £32.60p all is fine after about a dozen washes.
Hope this helps.
