I'm installing pond pump & lights in the garden & was considering using an Armadillo pre-assembled kit as it apparently is meets Regs & Part-P.
With the "Permenant Wired" kit with the junction box on the end, you obviously have to wire in your pump & lights.
But how far can you go, can I wire up a fancy new wireless dimmer switch in between the pump/lights & the junction box?
I assume there is a reasonable limit which this Armadilo kit is covers the regs? Otherwise when do I need to get in a sparky to do the job?
Cheers
Cheers
