Armoured cable termination
The former, given the likelihood that at some point you'll add garden lighting and sockets.
When you are down stream of an RCD, having further RCDs or RCBOs is completely pointless
But you’d know this if you had competence
You could gland off into an external box at low level, strip the swa really long and run up to the Dist Board in flexi conduit, maybe with a seperate extra earth wire to allow bonding the armour, within the partition wall, that would leave the gland accessible and no unnecessary joints
It would need rcd protection doing it that way.
yes it does, i believe the op said there was already an rcd at the source
I had another idea after reading yours, do what you said but install the swa inner inside a galvanised trunking inside the wall? No rcd protection needed then.
It will but the shed board not isolating a socket mounted on shed is not ok
Any particular reason?
We have fairly often had threads where a shed supply is added to an outside socket and 'off the top of my head' I don't recall it being a big no-no before, sure there were discussions about suitability for the situation but in principle a 13A socket on a 32A circuit is okay.
