Asbestos?
10 Jan 2010
London
Just a quick check pls. Installing a light outside my front door. Been a bit too aggressive and some plaster came off the ceiling. From the upstairs room everything looks like standard lath and plaster. I see some horsehair, but wondering about these white lines…
You can put a match to is as asbestos glows and don't burn.
Is that soft?
It's unusual. Looks a bit like fibre board but I don't know without poking it.
Probably worth getting a test done before you proceed as cheap enough. Play it safe
Top side is regular lath and plaster. Just not sure if there us a thin extra layer of some insulating stuff there.
I have repaired one like that.
I cut ply and screwed over the top through and put a wooden molding around the edges.
Probably just lath and plaster ceiling then. Can't say if it contains asbestos. Pulled loads off ceilings down over the years though
Plaster. And plaster does not have asbestos in it
You can't see asbestos fibres with the naked eye either.
